My destination directory is on a drobo. I experienced some power outages and the drive was going very slow for all file access. I was going to do a chkdsk and after 10 days it had only completes 60%. So I formatted the drobo. Now my file access speed is much better. It is in the process of performing backups now but do I need to do anything to tell the server that the old backup data is no longer present or will the server figure it out.
rkshack
You’ll need to run the remove_unknown batch/script.
You don’t mention which drobo, they’re known to slow quite dramatically as they fill in some circumstances, also because of the thin-provisioning & the way UrBackup is designed to manage space I’d strongly recommend enabling the drobo “Backup Volume” feature in drobo dashboard & using that as UrBackup’s storage, rather than the main volume.
Thanks for the help. I have a drobo S. I don’t think that setting is an option.
rkshack
