When I changed hardware for my Urbackup server, I found that it had only corrected the backup directory path for new backups. As a result, all symbolic links prior to migration are broken.
Here are the commands used to move data from one server (nfs1) to another (pbs14200) :
rsync /media/vol1/urbackup/ --archive --compress --delete --hard-links root@pbs14200.inframshe.univ-fcomte.fr:/mnt/datastore/datastore0/urbackup
rsync /var/urbackup/ --archive --compress --delete --hard-links root@pbs14200.inframshe.univ-fcomte.fr:/var/urbackup
As you can see, the paths to the backup directory differ from one server to another: the first uses a Dell MD1000 ext4/RAID6 array mounted on /media/vol1/urbackup, while the second uses ZFS storage on an HPE Apollo 4200 mounted on /mnt/datastore/datastore0.
In this thread, I propose a script that allowed me to solve the problem.
First, here’s the command to find broken symbolic links:
find /mnt/datastore/datastore0/urbackup -xtype l -exec ls -l {} +
Before writing a script, let’s take a look at how the problem arises and how it can be corrected for a given broken symbolic link.
The following link is broken and is displayed in red in the Bash terminal.
ls -l /mnt/datastore/datastore0/urbackup/pgisdata-mshe.univ-fcomte.fr/231109-1933/.hashes/etc/cron.daily
lrwxrwxrwx 1 urbackup urbackup 99 Nov 9 19:33 /mnt/datastore/datastore0/urbackup/pgisdata-mshe.univ-fcomte.fr/231109-1933/.hashes/etc/cron.daily -> /media/vol1/urbackup/pgisdata-mshe.univ-fcomte.fr/.directory_pool/JE/JEIllloCKt16925479922169876288
/media/vol1/urbackup/pgisdata-mshe.univ-fcomte.fr/.directory_pool/JE/JEIllloCKt16925479922169876288 no longer exists as it has been moved to /mnt/datastore/datastore0.
Here is the bash command to correct broken symbolic link:
ln -sf /mnt/datastore/datastore0/urbackup/pgisdata-mshe.univ-fcomte.fr/.directory_pool/JE/JEIllloCKt16925479922169876288 /mnt/datastore/datastore0/urbackup/pgisdata-mshe.univ-fcomte.fr/231109-1933/.hashes/etc/cron.daily
Let’s implement this in a correction script. I can’t take much credit for this, as I admit I used ChatGPT to help me with this task.
#!/bin/bash
# Fixing broken symbolic links in Urbackup backups
# Define the path of the old and new directories
old_path="/media/vol1/urbackup"
new_path="/mnt/datastore/datastore0/urbackup"
# Directory path to traverse
directory_path="/mnt/datastore/datastore0/urbackup"
# Find all symbolic links containing the old path and correct them
find "$directory_path" -type l | while read -r link; do
# Check if the symbolic link contains the old path
if [ "$(readlink "$link" | grep "$old_path")" ]; then
# Extract the part of the path after the old directory
old_part=$(readlink "$link" | sed "s|$old_path||g")
# Create the new link by replacing the old path with the new one
new_link="$new_path$old_part"
ln -sf "$new_link" "$link"
echo "The link $link has been corrected to $new_link"
fi
done
Don’t be in a hurry… Running this script takes time (several days), especially if the server manages other types of backup in the same backup location (Borgbackup and Proxmox Backup Server, in my case).
I hope this feedback will be useful…
Ernest.
