I´m testing Urbackup - so far a nice experience. I have a problem with multiple warnings (+1000) in an otherwise succesfull backup of SUSE SLES12 SP2.
There are a lot of entries like: Warnings 07/02/17 10:43 Filename “136:0” contains ‘:’ which the operating system does not allow in paths. Replacing ‘:’ with '’ and appending hash._
Can anyone explain the true nature of this warning - I understand the words - but not sure I understand why.
Running Server 2.1.16 beta on Windows Server 2012R2. Client running ver. 2.0.36.
Try creating a file with : in the file name on Windows
What is the full path of those files? If it is some special file system or something like /dev it should be excluded because it does not make sense to backup those.
Sorry for adding a bad example. Here´s another one - but offcourse that would impose the same problem with Windows not able to support those characters in filenames. Question is, how will a restore of same object behave - when Urbackup replaces * with a _ and appending hash?
-rw-r–r-- 1 root root 395 Jan 7 07:08 config-mandrake-linux-10.1-*
Hmm. What´s wrong with my exclusions. Are these right or wrong - it seems the Backup Server doesn´t take them into considerations but keeps up with bckup these directories.
Are you positive that your exclusions have the appropriate separators?
That is also strange because it is normally '' that you cannot put something in front of because it’s a special character, otherwise ‘\*’ would look like ‘*’.
examples:
/usr/libexec/webmin/ldap-server/config-freebsd-8-* ( not a big deal - it is hardly used)
/home/xxuserxx/Maildir/.Sent Messages/cur/1476030509.M749536P17979.ThePostmaster,S=360,W=377:2,S (from imap folder)
/etc/zypp/repos.d/SUSE_Linux_Enterprise_Server_12_SP2_x86_64:SLES12-SP2-Source-Pool.repo (repository listing i presume).
There are more places/directories - and as stated not all are equally important, but it takes some effort to exclude directories. Another question is, how it will behave in a restore situation.
I am having difficulty on how to deal with it - or not.
