Hi! I’m currently still using the Fedora 38 packaging from OBS. Is there anything I can help to get a repo running for Fedora 40?
Best would be to fork Show home:uroni / urbackup-server - openSUSE Build Service , get it to work, then make a PR for the spec file
I triggered builds for the four architectures on F39 and F40, and it seems that the build succeeds on aarch64 and x86_64. armv7hl failed on F38 too, but now also ppc64le fails because of a broken repository setup. I’m not sure whether there’s something special to your own repository setup for ppc64le that I overlook? I just took the upstream ones available on OBS.
I think the check boxes for those were just unchecked? I checked them now…
Looks fine indeed, and upgraded successfully on my machine! Thanks
