Hello uroni,
urbackup is great. But there’s something that I think it’s missing: having many notebooks/windows tablets or 2in1, I’d love to back up them with urbackup. The problem is: it would be great to have an option (also for Macs and Linux) to enable/disable backups when on battery, to avoid battery drain.
From what I can see there is no API that allows you to ‘pause’ a backup (although it is in the GUI, it isn’t exposed in CLI) but you could perhaps use a pre-backup script that ‘checks’ your charge status and exits with a non-zero code if it’s not on AC power. That would prevent your backup from ‘starting’ but not interrupt a running backup. If there were ever a PAUSE command in the CLI, you could have it trigger on a state change. Not sure if that’s something that’s easy to build into the C code.
On OS X you could use “pmset -g batt” and parse the first line.
On Windows “WMIC Path Win32_Battery”
On Linux use upower or a value from the /sys/class/power_supply tree (depending on kernel version, hardware and software installed, YMMV)
