Feature request (And a problem)
Hi All,
I have noticed that the Urbackup 1.47 server process is down and not responiding to http request on my install,
I suspect it’s a load issue on the database but I can find anything in the logs.
So I have started to limit the number of concurrent backups to 3.
While currenlty 3 backups are running I have clicked on start backup for addational 5 servers and nothing happens,
So you cannot add addational backups while you are in the limit.
May I suggest one of the two options,
  1. Error message will be nice.
  2. Add activities as pending activities with a list just above the last activities.
And thank you for the great product.
Okay. Taken into consideration.
Next time the web interface is unresponsive you could either send me a memory dump of the process or enable debug logging. It logs the active Database queries if they are longrunning.
