- Client v 2.5.25 (Windows 11)
- Server v2.5.31 (QNAP QTS)
Hi, i have a single client with the below errors:
Errors 11/03/23 06:10 FATAL: Error writing to VHD-File. Code 0
Errors 11/03/23 06:10 FATAL ERROR: Could not write to VHD-File
We have other systems backing up ok, all iver 500Gb, the error is a drive thats 2.42Tb, we use Compressed VHD.
Whats the difference between compressed and non compressed? I am hoping both only write the file size of data they use and not the complete 2.42Tb disk size. I also assume this is not a Volume Shadow size issue (or is it?)
We are unable to access the backend of the server (as its running on a QNAP QTS system) incase anyone needs logs that cant be seen in the Server Web GUI
