Cannot seem to get fastcgi working using ubuntu 12.04 LTS and urbackup version 1.3.2
Followed the docs and added a symlink to my ssl document root i included some of my default-ssl file below just to confirm
[quote=""]ls -l
total 4
-rw-r–r-- 1 root root 177 Oct 5 2012 index.html
lrwxrwxrwx 1 root root 21 Mar 6 02:51 urbackup -> /var/lib/urbackup/www[/quote]
<IfModule mod_ssl.c>
<VirtualHost _default_:443>
DocumentRoot /var/www
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from all
</Directory>
I installed libapache2-mod-fastcgi from multiverse and have the following lines inmy /etc/apache2/modules-enabled/fastcgi.conf
[quote=""]
AddHandler fastcgi-script .fcgi
#FastCgiWrapper /usr/lib/apache2/suexec
FastCgiIpcDir /var/lib/apache2/fastcgi
urbackup
FastCgiExternalServer /var/www/urbackup -host 127.0.0.1:55413
[/quote]
but i always get this error in my browser
[b]SSL connection error
Unable to make a secure connection to the server. This may be a problem with the server, or it may be requiring a client authentication certificate that you don’t have.
Error code: ERR_SSL_PROTOCOL_ERROR[/b]
Here is the only warning in my apache logs but i think CA is ok since it is self signed right?
[Thu Mar 06 03:54:39 2014] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
