Hi All,
I just updated my server to 2.0.30 and I’ve got two little things going on -
I’m not sure if FastCGI is working properly - it was working before with my previous install (1.0.47 I think it was) just fine. All of the symbolic links are in place like they should be, and the configuration is correct on Apache, but I notice netstat is not showing anything listening on port 55413. I can access the http interface through 55414 just fine, so I know the non-FastCGI interface is working. Is this something I need to switch on once I can actually log into the updated server? This leads to below…
this on my web interface:
UrBackup is upgrading its internal database. This may take a while. The server is inaccessible and will not do any backups during this upgrade.
Current version: 35
Target version: 47
If I’m looking at the right file, the DB looks to be ~1.5GB in size, so any ideas as to how long this process should take?
