Anyway, the installation abruptly fails with just a few lines of output:
Verifying archive integrity... All good.
Uncompressing UrBackup Client Installer for Linux 100% Extraction failed.
Signal caught, cleaning up
I also tried to launch the script with the –target option, specifying an existing folder. This happens: the folder changes owner (user and group), a file named install-data.tar.gz is created inside, and the output of the install command is slightly different. The installation fails anyway:
Creating directory urbackup_setup
Terminated
Any idea about to fix this issue? Please note that this client has no GUI and has no Internet access (it should reach the UrBackup server in the same network).
I found the cause of the problem… It was caused by the “double transfer” via FTP in automatic mode.
The file downloaded on my Windows PC had the correct MD5. But after uploading it on the “real” client the MD5 got changed… every time in a different way.
I re-uploaded the file in binary mode and it got transferred correctly… after that, the installation worked
Thanks for the support… maybe I’ll probably ask again on the forum for the next steps
