Does UrBackup automatically exclude virtual file systems like /dev
and /sys
? Or should they be excluded manually?
Is this unknown?
Why don’t you use snapshots? Snapshot mounts without (virtual file systems like /dev
and /sys
If you don’t use snapshots exclude this folders manually for be sure that they will be exclude.
Excluded files (with wildcards): /dev/*;/run/*;/sys/*;/proc/*
Thanks for your reply. I don’t have enough space in my VGs for snapshots.
But that doesn’t really answer this question…
No one?
Assuming virtual file systems do not have to be excluded manually when a file system at /
was added with the -x
option.
