Hi again, I’ve search the forum and www about my next inquiry, but didn’t not find an answer to this.
Therefore i hope for find any infos here.
Now to the cause of my post:
On all of my XP machines (i know, i should switch to something newer) i get the following log error in UrBackup: Writer MSDEWriter has failure state VSS_WS_STABLE with error VSS_E_WRITERERROR_NONRETRYABLE. UrBackup will continue with the backup but the associated data may not be consistent.
2014-03-10 17:04:18(info): Starting full file backup…
2014-03-10 17:05:40(error): Writer MSDEWriter has failure state VSS_WS_STABLE with error VSS_E_WRITERERROR_NONRETRYABLE. UrBackup will continue with the backup but the associated data may not be consistent.
2014-03-10 17:05:40(info): Indexing of “PC001” done. 8 filesystem lookups 0 db lookups and 0 db updates
2014-03-10 17:05:40(info): Starting shadowcopy “PC001”.
2014-03-10 17:05:54(info): Stoping shadowcopy “PC001”.
2014-03-10 17:05:56(info): Transferred 8.20883 MB - Average speed: 4.12932 MBit/s
2014-03-10 17:05:57(info): Time taken for backing up client LecicServer: 1m 39s
Hi, I am having the same error with one of my Windows XP machines…
Level Time Message
Info 18.03.14 01:17 Starting incremental file backup…
Errors 18.03.14 01:19 Writer MSDEWriter has failure state VSS_WS_STABLE with error VSS_E_WRITERERROR_NONRETRYABLE. UrBackup will continue with the backup but the associated data may not be consistent.
Info 18.03.14 01:19 Indexing of “My Documents” done. 4 filesystem lookups 370 db lookups and 3 db updates
Info 18.03.14 01:19 Indexing of “My Documents_0” done. 1 filesystem lookups 4 db lookups and 0 db updates
Info 18.03.14 01:19 Indexing of “My Documents_1” done. 1 filesystem lookups 4 db lookups and 0 db updates
Info 18.03.14 01:19 Indexing of “Automation Premium” done. 6 filesystem lookups 491 db lookups and 5 db updates
Info 18.03.14 03:13 Transferred 8.93999 MB - Average speed: 11 KBit/s
Info 18.03.14 03:13 Time taken for backing up client DRYSERVER: 1h 55m 48s
I have attempted to find any logs for the VSS service but struggling with this (believe i need to change some registery settings or install VSS SDK). Aparantly I can
find out more information my using vssadmin command straight after the problem occurs. I will try this tonight when the machine is not in use. Currently vssadmin shows no issues (but it has been 8 hours since last backup completed) I will do some more tests tonight. here is current vssadmin output showing everything ok…
