debug.log.1.txt.zip (40.1 KB) GM fellow urbackers!
so I am getting this infamous error on a few clients…:
Errorcode: BASE_DIR_LOST (7)
I have been looking through the docs and forums article about it but I can’t seem to get rid of the problem…
so far, I have tried the following using a tiny empty workstation client (windows 10) as a sample.
from the doc:
confirmed the drive has plenty of spare disk space
confirmed that nothing is going on at the time of the backup on the client
tried to increase the shadow storage
from the forums:
deleted all existing shadow copies that I could find…
tried to switch from default settings to client specific listing individual drives instead of all: (ie: from ALL -> C:;D:;F:)
urbackupsrv remove-unknown
urbackupsrv repair-database
Any suggestions?
here is the log from the client as seen by the server (debug)
I am also attaching a debug file from the client side which seems to have more details from an earlier attempt…
10/04/19 08:53 DEBUG Reflink copying is enabled
10/04/19 08:53 INFO Starting unscheduled full file backup…
10/04/19 08:53 DEBUG dodo: Connecting for filelist…
10/04/19 08:53 DEBUG dodo: Waiting for filelist
10/04/19 08:53 DEBUG dodo: Connecting for filelist (async)…
10/04/19 09:00 INFO Selected no components to backup
10/04/19 09:00 INFO Indexing of “ALL” done. 57615 filesystem lookups 0 db lookups and 0 db updates
10/04/19 09:00 DEBUG dodo: Doing backup with hashed transfer…
10/04/19 09:00 INFO dodo: Loading file list…
10/04/19 09:00 INFO dodo: Started loading files…
10/04/19 09:00 DEBUG Starting shadowcopy “ALL”.
10/04/19 09:00 DEBUG Loading file “BOOTNXT”
10/04/19 09:00 ERROR Error getting complete file “mqqwRzvWqEhNwRNKjz0l|ALL/BOOTNXT” from dodo. Errorcode: BASE_DIR_LOST (7)
10/04/19 09:00 INFO Hint: Current root backup path does not exist anymore. Usually this is because the current file system snapshot it was backing up was deleted because it ran out of snapshot storage space. See https://www.urbackup.org/faq.html#base_dir_lost for details and for how to fix this issue
10/04/19 09:00 ERROR Client dodo went offline.
10/04/19 09:00 INFO Waiting for file transfers…
10/04/19 09:00 INFO Waiting for file hashing and copying threads…
10/04/19 09:00 DEBUG Metadata of “…” missing
10/04/19 09:00 DEBUG Some metadata was missing
10/04/19 09:00 DEBUG Syncing file system…
10/04/19 09:00 INFO Transferred 21.0363 MB - Average speed: 116.019 MBit/s
10/04/19 09:00 DEBUG Script does not exist urbackup/post_full_filebackup
10/04/19 09:00 INFO Time taken for backing up client dodo: 7m 22s
10/04/19 09:00 ERROR Backup failed
