Error removing xattrs of %FILENAME%
Getting an error for each file when restoring a backup. Is this anything to worry about?
Server: 2.1.16, CentOS 7
Client: 2.1.13, CentOS 7
Do you have a log to show exactly what it is doing?
If you don’t want it to be public knowledge of what your logs are you can always follow this:
Oh, no issue at all with reluctance to show logs, it’s just that it’s all it says:
2017-02-09 15:44:10: Applying file metadata…
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/.pwd.lock
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/.updated
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/DIR_COLORS
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/DIR_COLORS.256color
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/DIR_COLORS.lightbgcolor
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/GREP_COLORS
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/GeoIP.conf
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/GeoIP.conf.default
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/NetworkManager/NetworkManager.conf
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/NetworkManager/VPN
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/NetworkManager/conf.d
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/NetworkManager/dispatcher.d/00-netreport
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/NetworkManager/dispatcher.d/11-dhclient
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/NetworkManager/dispatcher.d/20-chrony
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/NetworkManager/dispatcher.d/no-wait.d
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/NetworkManager/dispatcher.d/pre-down.d
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/NetworkManager/dispatcher.d/pre-up.d
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/NetworkManager/dnsmasq-shared.d
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/NetworkManager/dnsmasq.d
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/NetworkManager/system-connections
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/X11/applnk
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/X11/fontpath.d
2017-02-09 15:44:10: ERROR: Error removing xattrs of /etc/X11/xorg.conf.d/00-keyboard.conf
2017-02-09 15:44:10: Restore finished successfully.
Keep in mind that this goes for every file in restore, left out a ton for brevity. Not sure if relevant but in this case I removed the whole /etc dir and restored it.
