Writer MSDEWriter has failure state VSS_WS_STABLE with error VSS_E_WRITERERROR_NONRETRYABLE UrBackup will continue with the backup but the associated data may not be consistent.
Ur Backup 1.3.1
18.12.13 19:17 DEBUG Getting client settings…
18.12.13 19:17 DEBUG Sending backup incr intervall…
18.12.13 19:19 INFO Starting incremental file backup…
18.12.13 19:19 DEBUG pabx_sw: Connecting for filelist…
18.12.13 19:19 DEBUG pabx_sw: Waiting for filelist
18.12.13 19:20 ERROR Writer MSDEWriter has failure state VSS_WS_STABLE with error VSS_E_WRITERERROR_NONRETRYABLE UrBackup will continue with the backup but the associated data may not be consistent.
18.12.13 19:20 INFO Indexing of “TelSoft” done. 1 filesystem lookups 1 db lookups and 0 db updates
18.12.13 19:20 DEBUG pabx_sw: Doing backup with hashed transfer…
18.12.13 19:20 DEBUG pabx_sw: Loading filelist…
18.12.13 19:20 DEBUG pabx_sw Starting incremental backup…
18.12.13 19:20 DEBUG pabx_sw: Calculating file tree differences…
18.12.13 19:20 DEBUG pabx_sw: Calculating tree difference size…
18.12.13 19:20 DEBUG pabx_sw: Linking unchanged and loading new files…
18.12.13 19:20 DEBUG Creating symbolic links. -1
18.12.13 19:20 DEBUG Creating symbolic links. -2
18.12.13 19:20 DEBUG Symbolic links created.
18.12.13 19:20 INFO Transferred 8.05469 KB - Average speed: 41.056 KBit/s
18.12.13 19:20 INFO Time taken for backing up client pabx_sw: 48s
It’s probably an error by “MSDEWriter” (Microsoft SQL Server?), not UrBackup.
You may find further help by googling “MSDEWriter” and “VSS_E_WRITERERROR_NONRETRYABLE” or by looking if there are any errors in the system error log.
