Hello, I need help, I have a ubuntu server 20.04 served, it indicates an error in the socket 55414 and 55413. When connecting to the clients, only a first copy was made, then I no longer perform. The firewall already has the port exclusions.
2020-08-16 20:13:08: Starting HTTP-Server on port 55414
2020-08-16 20:13:08: ERROR: HTTP: Failed binding socket to port 55414. Another instance of this application may already be active and bound to this port.
2020-08-16 20:13:08: Started UrBackup…
2020-08-16 20:13:08: Removing temporary files…
2020-08-16 20:13:08: Recreating temporary folder…
TEST FAILED: guestmount is missing (libguestfs-tools)
2020-08-16 20:13:08: Image mounting disabled: TEST FAILED: guestmount is missing (libguestfs-tools)
2020-08-16 20:13:08: Testing if backup destination can handle subvolumes and snapshots…
Testing for btrfs…
ERROR: not a btrfs filesystem: /media/BACKUP/urbackup/
Testing for zfs…
2020-08-16 20:13:08: Backup destination cannot handle subvolumes and snapshots. Snapshots disabled.
2020-08-16 20:13:08: Testing if backup destination can handle filesystem transactions…
2020-08-16 20:13:08: Testing for hardlinks in backup destination…
2020-08-16 20:13:08: Could create hardlink at backup destination. Hardlinks enabled.
2020-08-16 20:13:08: Testing for reflinks in backup destination…
2020-08-16 20:13:08: Reflink ioctl failed. errno=95
2020-08-16 20:13:08: Could not create reflink at backup destination. Reflinks disabled. Operation not supported (code: 95)
2020-08-16 20:13:08: Binding to interface ens160 (ipv4) for broadcasting…
2020-08-16 20:13:08: Broadcasting on ipv4 interface ens160 addr 192.168.1.12
2020-08-16 20:13:08: Binding to interface ens160 (ipv6) for broadcasting…
2020-08-16 20:13:08: Broadcasting on ipv6 interface ens160 addr fe80::20c:29ff:fef9:a800
2020-08-16 20:13:08: ERROR: InternetService: Failed binding socket to port 55415. Another instance of this application may already be active and bound to this port.
2020-08-16 20:13:08: UrBackup Server start up complete.
2020-08-16 20:13:08: ERROR: Failed binding SOCKET to Port 55413
2020-08-16 20:13:08: ERROR: Error while starting listening to ports. Stopping server.
2020-08-16 20:13:08: Exited Loop
2020-08-16 20:13:08: Deleting at…
2020-08-16 20:13:08: Deleting SelectThreads…
2020-08-16 20:13:08: Deleting lbs…
2020-08-16 20:13:08: Shutting down plugins…
2020-08-16 20:13:08: Deleting server…
Segmentation fault (core dumped)
