The proxy does not work with environment variables yet. Thanks for the heads up!
If you need to get autoupdate to work (This is the only thing that needs Internet) you could give the proxy and port as parameters to urbackup_srv
e.g. by --http_proxy xxx.xxx.xxx.xxx --http_proxy_port 3128
Yes, sorry you need to add those parameters to DAEMON_ARGS in /usr/sbin/start_urbackup_server
It downloads new client versions (there isn’t one for 1.0 yet) from http://update1.urbackup.org/ and then updates the clients. There is not autoupdate for the server. You can also manually download all files from the previous address and put them into /var/urbackup – once there is a new version – to update the clients.
I downloaded the latest exe to this location but did not see any client updates. The test client is running exe version 1.0 and was rebooted twice. Am I missing something?
ls -al /var/urbackup/UrBackup\ Client\ 1.1.1-1.exe
-rw-r--r-- 1 urbackup urbackup 14278371 Feb 17 20:31 /var/urbackup/UrBackup Client 1.1.1-1.exe
