Error cleaning the storage folder of files not known by UrBackup
Hi, after upgraded a Linux server with urbackup 1.4.11 to 2.0 all windows clients are not seen. I try to run this command to fix symlinks and all but at the end I’ve an error. What’s the matter?
`urbackupsrv remove-unknown
2016-07-21 09:25:12: Going to remove all unknown files and directories in the urbackup storage directory. Waiting 20 seconds…
2016-07-21 09:25:32: Shutting down all database instances…
2016-07-21 09:25:32: Opening urbackup server database…
2016-07-21 09:25:35: Testing if backup destination can handle subvolumes and snapshots…
TEST FAILED: Creating test subvolume failed
2016-07-21 09:25:35: Backup destination cannot handle subvolumes and snapshots. Snapshots disabled.
2016-07-21 09:25:35: Transitioning urbackup server database to different journaling mode…
2016-07-21 09:25:35: LockForTransaction in CQuery::Execute Stmt: [PRAGMA journal_mode = DELETE]
2016-07-21 09:25:35: SQLITE_BUSY in CQuery::Execute Stmt: [PRAGMA journal_mode = DELETE]
2016-07-21 09:25:35: Active query(0): PRAGMA journal_mode = DELETE
2016-07-21 09:25:35: ERROR: SQLITE: Long running query Stmt: [PRAGMA journal_mode = DELETE]
2016-07-21 09:25:35: ERROR: Active query(0): PRAGMA journal_mode = DELETE
You must stop the urbackup service before running the command.
Regards,
Thanks very much!
