I have a question.
I have configured a new server in Cloud storage mode with cache disk. I have configured a single client that totals 1.6TB of data to backup.
I forgot to set the cloud size correctly (1TB) and so the backup stopped asking for a backup reset.
Now the backup works correctly after enlarging the cloud storage but there is an error. There should not be so much on the cloud storage. I think that the backup reset did not delete properly. Storage Cloud 1.94To
From the log you sent me my current hypothesis is that it just takes a long while to delete. This might be exacerbated by the non-shard optimized delete (because of https://tracker.ceph.com/issues/41642 ).
You can verify it is still deleting by going to Settings -> System -> Advanced: Access server statistics (netdata) (you might need to do this twice). Then go to storage -> clouddrive and look at del ops/s in Asynchronous IO operations.
