dattobd is supported on Debian, but the existing UrBackup Linux client script doesn’t allow it. Is there a particular reason for this? I was thinking of just adding next to the existing checks in the install script e.g.,
if [ $DEBIAN != no ]
then
echo "+Detected Debian. Dattobd supported"
DATTO=yes
fi
… but then the integrity checks fail. However it would seem that all the detection does is change /usr/local/etc/urbackup/snapshot.cfg to:
create_filesystem_snapshot=/usr/local/share/urbackup/dattobd_create_filesystem_snapshot
remove_filesystem_snapshot=/usr/local/share/urbackup/dattobd_remove_filesystem_snapshot
If I install the script with “4) Use no snapshot mechanism” option, will I only need the above edit to snapshot.cfg to enable dattobd support? Is there any way I can verify dattobd snapshot is being used?
