How can i customize the server (UrBackup Server 2.1.19) activity log messages or texts. Are this text messages in the javascript files or embedded in the executable program? Can one customize any part of this server application?
You could change the source files and compile the server yourself, or if the strings you want to replace are in the javascript then it’s probably just a www folder somewhere to replace. Search for the messages you want to change in the urbackup source files to find out.
