https://www.urbackup.org/administration_manual.html
I know that it is pretty straight forward from what I have attempted so far with the Restore CD 1.1.1 for a Windows Client, but there is not a whole lot of documentation in the Administrative Manual for this:
- How does the restoration work?
- I am currently using the Restore CD for a machine, but it constantly freezes up at the 24% mark.
- Do I have to build a disk image before I restore, or just restore from a .vhdz file?
- Can I manually build a disk image that is NOT a .vhd file without needing 3rd-party resources (like an ISO or IMG file)?
- Can you only create .vhd files from the compress_image.bat and assemble_disk_image.bat on Windows?
- Is the method I have listed off so far only viable for virtual machines?
- (I thought I would ask) Does it support SSD support and if so, does it support HDD-to-SSD restore (HDD being the source and SSD being the destination)?
While using the Restore CD is very straight-forward, it just feels like it was glossed over when mentioned: https://www.urbackup.org/administration_manual.html#x1-760009.7
