I’m looking to make a docker of the server side of urbackup and have persistent settings, i can make a docker that keeps the databases and settings internal to the image.
However this is not ideal as any update or edit to the image destroys the settings, but if i try to have a volume with the databases on storage outside the image i get these errors.
/usr/bin/docker logs --tail=350 -f UrBackup 2>&1
2015-04-05 15:52:42: ERROR: Error preparing Query [SELECT tvalue FROM misc WHERE tkey=‘db_version’]: no such table: misc
2015-04-05 15:52:42: ERROR: Error preparing Query [CREATE INDEX IF NOT EXISTS files_idx ON files (shahash, filesize, clientid)]: no such table: main.files
2015-04-05 15:52:42: ERROR: Error preparing Query [CREATE INDEX IF NOT EXISTS files_did_count ON files (did_count)]: no such table: main.files
2015-04-05 15:52:42: ERROR: Error preparing Query [CREATE INDEX IF NOT EXISTS files_backupid ON files (backupid)]: no such table: main.files
2015-04-05 15:52:42: ERROR: Error preparing Query [SELECT value FROM settings_db.settings WHERE key=? AND clientid=0]: no such table: settings_db.settings
2015-04-05 15:52:42: ERROR: Error preparing Query [UPDATE misc SET tvalue=? WHERE tkey=‘files_cache’]: no such table: misc
2015-04-05 15:52:42: ERROR: Error preparing Query [SELECT linkname, linktarget FROM directory_link_journal]: no such table: directory_link_journal
2015-04-05 15:52:54: ERROR: Error preparing Query [SELECT tvalue FROM misc WHERE tkey=‘db_version’]: no such table: misc
2015-04-05 15:52:54: ERROR: Error preparing Query [CREATE INDEX IF NOT EXISTS files_idx ON files (shahash, filesize, clientid)]: no such table: main.files
2015-04-05 15:52:54: ERROR: Error preparing Query [CREATE INDEX IF NOT EXISTS files_did_count ON files (did_count)]: no such table: main.files
2015-04-05 15:52:54: ERROR: Error preparing Query [CREATE INDEX IF NOT EXISTS files_backupid ON files (backupid)]: no such table: main.files
2015-04-05 15:52:54: ERROR: Error preparing Query [SELECT value FROM settings_db.settings WHERE key=? AND clientid=0]: no such table: settings_db.settings
2015-04-05 15:52:54: ERROR: Error preparing Query [UPDATE misc SET tvalue=? WHERE tkey=‘files_cache’]: no such table: misc
2015-04-05 15:52:54: ERROR: Error preparing Query [SELECT linkname, linktarget FROM directory_link_journal]: no such table: directory_link_journal
is there a remedy for this or a command line setting to combat this ?
Thanks for any assistance
