Ok, i’ve tried a few times to deploy and I know there are lots of moving parts. I keep getting access denied to the /backups folder. I have a samba share mounted to /mnt/UrBackup and i have /mnt/Urbackup in the deploy to /backups. If I execute a shell from inside the docker container i can write a file and a dir. If I check the share they show up fine. So I think I am close…the docker container is on x.x.x.23 and the cifs share is on a different machine x.x.x.22 if that matters.
The directory where UrBackup will save backups is inaccessible. Please fix that by modifying this folder in ‘Settings’ or by giving UrBackup rights to access this directory. (err_cannot_create_subdir). Permission denied (code: 13)
The webserver starts without issue and i even found a client. What am I overlooking?
