I am wondering if the server can display a warning on finding that the paths in backupfolder mismatches across various directories. On my install I have a file called backupfolder in:
/etc/urbackup
/var/urbackup
This is a Ubuntu 16.04 install from the PPA. This mismatch caused btrfs snapshots to silently fail. I suspect it also caused my restores to “fail” (I just copied the files from the backup dir myself)
Cheers,
Pieter
