In one of my Urbackup server logs, I am finding a WARNING that it can’t delete a Client_Image.vhdz.bitmap file. When I look in a newer image directory for this client, I only find Client_Image.vhdz.cbitmap
On a different Urbackup server which is a similar setup, it does not have any warnings in it’s log file. Those clients also only have the cbitmap files in current image directories.
Question is, did it update the database to reflect the file it can’t delete not being there? Which would also be a cure.
If you’re running a Windows server, I’d also suggest
CHKDSK /scan /perf
on the storage drive.
Also, manually deleting the file then running remove-unknown again to alert UrBackup to the fact it’s no longer there.
If it’s not there & you’re still getting the error, copy any random file to the directory it’s missing from & give it the appropriate name, so there is something to be deleted.
After that, it’s database tools & working with the database directly (YUK!).
