for those interested in trying beesd with btrfs. this is my weekly cron script:
beesd output is saved and rotated&compressed under /var/log/bees.$UUID.$WEEK_NUMBER.log
#!/bin/ksh
# we assume that the cleanup happens weekly so the log files get saved under the week-of-the-year
# which allows to rotate logs on a yearly basis. adjust as needed...
TSTAMP=` date +%W`
# -v add extra infos when running manually.
if [[ $1 == "-v" ]]
then
VERBOSE=true
else
VERBOSE=false
fi
$VERBOSE && set -x
cd /etc/bees
for config_file in *-*-*-*-*.conf
do
uuid=`echo $config_file |cut -f1 -d. `
uuid_mount=`grep $uuid /etc/fstab | awk '{print $2}'`
mylogs="/var/log/bees.${uuid}.${TSTAMP}.log"
[[ -a /var/log/bees.${uuid}.*.log ]] && gzip /var/log/bees.${uuid}.*.log
$VERBOSE && print parsing $uuid
$VERBOSE && print saving logs at $mylogs
size_before=`df -h $uuid_mount |awk '{print $2}'|tail -1`
date > $mylogs
df -h $uuid_mount >>$mylogs
beesd "$uuid" >> $mylogs 2>&1
date >> $mylogs
size_after=`df -h $uuid_mount |awk '{print $2}'|tail -1`
done
