I 've installed urbackup on debian 7.1 with apache 2.2 yet and backup works fine - thanks
But I cannot get the Webinterface at work:
SSL is working, Apaches https ist working, but if I insert “FastCgiExternalServer /var/www/urbackup/x -host 127.0.0.1:55413” in the fcgi.conf or in apache2.conf theres a Syntaxerror when I restart Apache. The same with FcgidExternalServer.
The pathes is : /var/www with symlink as described.
I had that problem as well and thought they were fixed. I solved it by compiling the fastcgi package myself. Fcgi is not a replacement of fastcgi, as it does not have the “external server” option that fastcgi does. Apparently Debian has licence issues with the fastcgi module. Maybe we should file a bug against Debian?
You can download it here http://www.fastcgi.com/drupal/node/3 but getting it running was not trivial for me.
At this point running lighttp or some other server might well be easier.
Damn! I love Linux since many years, but I hate it for this problems. All privat projects I tried in the last time didn’t work becaus of similiar problems
Yes lets file a bugreport.
So what is better/easier- trying to compile the source or upgrade to 2.3 resp. upgrade to sid with apache 2.4 or trying ligttp ?I don’t know.
rdo2001
it works! At last it was simple. The missing package was in the non-free Repository!! I didn’t think at this restriktion because I changed back to debian from Ubuntu - which makes more and more own standards . To enable this mod I had to add two symlinks in /etc/apache2/mods-enabled to /etc/mods-available/fastcgi.conf and /etc/mods-available/fastcgi.load. Restart apache and it works. Fine. Thank you for your help and this software
