Debian squeeze is getting a bit old, and I would like to rebuild the debian packages with newer library versions. Where can I find the debian/ -directory contents used to make such a package?
Cheers,
Paul
Cheers,
Paul
the debian directory is here:
http://urpc.dyndns.org/urbackup-debian.tar.gz
And I once also tried to setup a PPA. That one is here: http://ppa.launchpad.net/uroni/urbackup/ubuntu/ (Maybe that helps)
I’ll be updating the documentation and then releasing a new version (1.0) found here currently https://sourceforge.net/projects/urbackup/files/Server/1.0RC/
so it would be better if you work with that one. It should also be easier because the configure script has the parameters
–enable-packaging and --enable-install_initd etc. where before that you had to patch the makefiles.
I’d really appreciate if someone took that burden from me!
