I am running the latest version of Urbackup and managed to create several image backups successfully.
Now when I tried to restore the images using the restore CD, the system showed the list of successful image backups to select. However the date and time stamps listed differ from the ones showing in the web interface.
I understanding that the time is showing according to the browser locale, so how can I make the locale of the restore CD the same with the web interface?
Do I make a custom CD or any changes to the source code required?
Yes I think it is using the default UTC for current_timestamp in sqlite.
A quick fix for this restore cd is probably to select the UTC timestamp from the database and then to reformat and display it as local time? For example, to use sqlite function:
