I finally upgraded to 2.1.19
Now, I wanted to try and use the dataplan limit feature to limit my users who are on verizon cell data connections (jetpack, smartphones, etc.) so they don’t go over their maximum data per month. I added *.myvzw.com 2000 (limit verizon connection to 2GB/month) to /var/urbackup/dataplan_db.txt, however, my changes were overwritten when urbackup server was restarted
I do not have an account on github, so I can’t make pull requests. I will add an account if I must, but I have a comment/question first…
I would think that I should be able to change the dataplan settings locally (best via the gui, but I would gladly change the text file). I think that a global setting is fine, but I would like to have a local way to override that in case my use is different. Is there some reason I haven’t thought of that makes a global system better? Is my understanding of the dataplan feature wrong?
Regards,
