Database location
Hello everyone,
It seems that urbackup server store its databases inside the backup location folder. For instance if the backup location is set to /media/backup then all the server databases are stored inside /media/backup/urbackup.
Is there a way to change this behavior ? We would like to store the databases somewhere else and use SSD drives while using slower hard drives for the backups data.
BTW : We are really amazed by the great job the dev has done.
Thanks for your help guys
afaik the database location is /var/urbackup
The files you see on your backup media are backups from urbackup itself.
