Creating root folders for `Default directories to backup`
Linux server and client in question.
Server version: 2.5.34
I’ve created 1 client, and joined it into a group since i would use default settings for these type of clients. I’ve set Default directories to backup to something like:
/opt/wildfly/standalone/configuration;/opt/wildfly/standalone/data;/etc/systemd/system/wildfly.service;/etc/systemd/system/traefik.service;/etc/wildfly/wildfly.conf;/opt/traefik
However (this is probably by design) when i check the backup contents, i see following in root:
configuration
data
wildfly.service
traefik.service
wildfly.conf
traefik
Without root folders. Is there any way to create backups with root folders? In above example, when i browse to: /opt/wildfly/standalone/configuration i would be able to see al files and folders, however any parent directory would be empty.
Additionally, inside /etc/systemd/system i would be able to see:
traefik.service
wildfly.service
But not any other file/folder.
Is this possible at all?
How would restore work if not? Would it know where to restore?
It stores the original path separately, so restore knows where to put it.
For what you want to do add the root folder /, then use the include_dirs setting.
How to use include_dirs ? I can’t find that in documentation:
On File Backups tab i have:
  • Included files (with wildcards) which has an ID of include_files
  • Default directories to backup which has an ID of default_dirs
  • Directories to backup are optional by default checkbox with an ID of backup_dirs_optional
Thanks in advance.
