I upgraded my server to 2.0.30. Then I went to one of my clients and downloaded its client from my server. It installed ok. That particular machine only does image backups. when it trys to do an incremental image backup I get
Could not read MBR
Cannot retrieve master boot record (MBR) for the disk from the client.
This was working under 1 series. I have tried removing urbackup reboot intall client downloaded from server but that has not solved the issue. I have tried going to server and forcing incremental backup but get same errors. Any ideas ?
I have been running server 2.0.29 for a week and have one client on 2.0.29 and it is working fine. Just added a brand new client using 2.0.29 on windows and now I am getting:
Errors 07/07/16 15:20 Could not read MBR
Errors 07/07/16 15:20 Cannot retrieve master boot record (MBR) for the disk from the client.
Errors 07/07/16 15:20 Backup failed
Update: After rebooting the client, backup has started and appears to be working.
The *.cbitmap files are created since 2.0.x, so this is a backward compatibility issue. Will fix it such that it has a fall back in case the cbitmap file does not exist. A full image backup should fix this as well.
An update if anyone has this issue. Uroni’s answer is the solution to all problems I had. So after upgrading have all clients do full image and full backup to avoid issues.
I have the same Problem since updatet from 1.4 to 2.0.31 (Client 2.0.30)
Operating System = Windows Server 2012 NO R2
Protokoll: (SERVER XXXX)
Level
Zeit
Nachricht
Fehler
02.08.16 14:54
Could not read MBR. Error message: Did not find PartitionNumber of dynamic volume. Volume: ‘D:’
Fehler
02.08.16 14:54
Fehler
02.08.16 14:54
Backup failed
Level
Zeit
Nachricht
Fehler
02.08.16 13:38
Fehler
02.08.16 13:38
Forcing a backup means telling server to do a backup, as in go to webinterface, choose a client and click on Full Image Backup. Forcing here is “doing a backup outside of intended backup window”
