I trying to install UrBackup Server 0.26.1-1 to my PC with Windows XP Operating system, then installation was successfully.
But when I tried to run and it will show this error " Oops! Google Chrome could not connect to 127.0.0.1:55414"
The one who can help me is very high appreciate.
Thank u so much…
uroni
September 10, 2012, 12:00am
2
Can you take a look into “C:\Program files\UrBackupServer\urbackup.log” and if this does not solve the issue post the messages here?
The port may be in use or a firewall may block the UrBackup server. You can change the port in “C:\Program files\UrBackupServer\args.txt”.
Thank you so much for the quick response.
Anyway, I found the solution by means of updating my OS WIndows xp Sp2 to Services Pack 3.
Your software is amazing very very useful, I recommend to all want to safe his/her file to backup.
Thank u so much
I am having the same problem I type in ip and port and sends me to hear. I have windows 8.1 I need help getting into the interface. Asap Thanks.
