Hello Community,
I am facing an issue with the UrBackup client on my network where the client is not accepting connections from the UrBackup server. I have the UrBackup client installed on a Linux machine and the server on a Windows machine. Both systems are within the same local network.
Client Version:
$ sudo urbackupclientbackend --version
UrBackup Client Backend v2.5.25.0
Copyright (C) 2011-2019 Martin Raiber
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Server (UrBackup 2.5.33) to Client:
PS D:\UrBackupServer> @(55413, 55414, 55415, 35623).ForEach({ Test-NetConnection -ComputerName "chuwi" -Port $_ | Select-Object ComputerName, TcpTestSucceeded, RemotePort })
WARNUNG: TCP connect to (192.168.178.173 : 55413) failed
WARNUNG: TCP connect to (192.168.178.173 : 55414) failed
WARNUNG: TCP connect to (192.168.178.173 : 55415) failed
WARNUNG: TCP connect to (192.168.178.173 : 35623) failed
ComputerName TcpTestSucceeded RemotePort
chuwi False 55413
chuwi False 55414
chuwi False 55415
chuwi False 35623
Client to Server:
$ sudo nmap -sT desktop-6p79g8t.local -p 55413,55414,55415,35623
Starting Nmap 7.80 ( https://nmap.org ) at 2024-05-13 18:39 UTC
Nmap scan report for desktop-6p79g8t.local (192.168.178.162)
Host is up (0.0028s latency).
rDNS record for 192.168.178.162: DESKTOP-6P79G8T.local
PORT STATE SERVICE
35623/tcp filtered unknown
55413/tcp open unknown
55414/tcp open unknown
55415/tcp open unknown
MAC Address: D8:BB:C1:43:13:90 (Unknown)
tcpdump Protocoll:
$ sudo tcpdump -i any 'tcp port (55413 or 55414 or 55415 or 35623) or udp port 35622'
tcpdump: data link type LINUX_SLL2
tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
listening on any, link-type LINUX_SLL2 (Linux cooked v2), snapshot length 262144 bytes
18:49:50.390927 enp1s0 In IP DESKTOP-6P79G8T.local.44282 > chuwi.local.55413: Flags [S], seq 428408656, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:49:50.391064 enp1s0 Out IP chuwi.local.55413 > DESKTOP-6P79G8T.local.44282: Flags [R.], seq 0, ack 428408657, win 0, length 0
18:49:50.912775 enp1s0 In IP DESKTOP-6P79G8T.local.44282 > chuwi.local.55413: Flags [S], seq 428408656, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:49:50.912899 enp1s0 Out IP chuwi.local.55413 > DESKTOP-6P79G8T.local.44282: Flags [R.], seq 0, ack 1, win 0, length 0
18:49:51.432293 enp1s0 In IP DESKTOP-6P79G8T.local.44282 > chuwi.local.55413: Flags [S], seq 428408656, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:49:51.432433 enp1s0 Out IP chuwi.local.55413 > DESKTOP-6P79G8T.local.44282: Flags [R.], seq 0, ack 1, win 0, length 0
18:49:51.951284 enp1s0 In IP DESKTOP-6P79G8T.local.44282 > chuwi.local.55413: Flags [S], seq 428408656, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:49:51.951429 enp1s0 Out IP chuwi.local.55413 > DESKTOP-6P79G8T.local.44282: Flags [R.], seq 0, ack 1, win 0, length 0
18:49:52.454016 enp1s0 In IP DESKTOP-6P79G8T.local.44282 > chuwi.local.55413: Flags [S], seq 428408656, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:49:52.454144 enp1s0 Out IP chuwi.local.55413 > DESKTOP-6P79G8T.local.44282: Flags [R.], seq 0, ack 1, win 0, length 0
18:49:55.452420 enp1s0 In IP DESKTOP-6P79G8T.local.44283 > chuwi.local.55414: Flags [S], seq 3909549676, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:49:55.452545 enp1s0 Out IP chuwi.local.55414 > DESKTOP-6P79G8T.local.44283: Flags [R.], seq 0, ack 3909549677, win 0, length 0
18:49:55.968389 enp1s0 In IP DESKTOP-6P79G8T.local.44283 > chuwi.local.55414: Flags [S], seq 3909549676, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:49:55.968509 enp1s0 Out IP chuwi.local.55414 > DESKTOP-6P79G8T.local.44283: Flags [R.], seq 0, ack 1, win 0, length 0
18:49:56.480303 enp1s0 In IP DESKTOP-6P79G8T.local.44283 > chuwi.local.55414: Flags [S], seq 3909549676, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:49:56.480439 enp1s0 Out IP chuwi.local.55414 > DESKTOP-6P79G8T.local.44283: Flags [R.], seq 0, ack 1, win 0, length 0
18:49:56.999605 enp1s0 In IP DESKTOP-6P79G8T.local.44283 > chuwi.local.55414: Flags [S], seq 3909549676, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:49:56.999750 enp1s0 Out IP chuwi.local.55414 > DESKTOP-6P79G8T.local.44283: Flags [R.], seq 0, ack 1, win 0, length 0
18:49:57.523793 enp1s0 In IP DESKTOP-6P79G8T.local.44283 > chuwi.local.55414: Flags [S], seq 3909549676, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:49:57.523919 enp1s0 Out IP chuwi.local.55414 > DESKTOP-6P79G8T.local.44283: Flags [R.], seq 0, ack 1, win 0, length 0
18:50:00.360157 enp1s0 In IP DESKTOP-6P79G8T.local.44287 > chuwi.local.55415: Flags [S], seq 3527866430, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:50:00.360287 enp1s0 Out IP chuwi.local.55415 > DESKTOP-6P79G8T.local.44287: Flags [R.], seq 0, ack 3527866431, win 0, length 0
18:50:00.868454 enp1s0 In IP DESKTOP-6P79G8T.local.44287 > chuwi.local.55415: Flags [S], seq 3527866430, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:50:00.868591 enp1s0 Out IP chuwi.local.55415 > DESKTOP-6P79G8T.local.44287: Flags [R.], seq 0, ack 1, win 0, length 0
18:50:01.388394 enp1s0 In IP DESKTOP-6P79G8T.local.44287 > chuwi.local.55415: Flags [S], seq 3527866430, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:50:01.388524 enp1s0 Out IP chuwi.local.55415 > DESKTOP-6P79G8T.local.44287: Flags [R.], seq 0, ack 1, win 0, length 0
18:50:01.908445 enp1s0 In IP DESKTOP-6P79G8T.local.44287 > chuwi.local.55415: Flags [S], seq 3527866430, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:50:01.908578 enp1s0 Out IP chuwi.local.55415 > DESKTOP-6P79G8T.local.44287: Flags [R.], seq 0, ack 1, win 0, length 0
18:50:02.416310 enp1s0 In IP DESKTOP-6P79G8T.local.44287 > chuwi.local.55415: Flags [S], seq 3527866430, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:50:02.416449 enp1s0 Out IP chuwi.local.55415 > DESKTOP-6P79G8T.local.44287: Flags [R.], seq 0, ack 1, win 0, length 0
18:50:05.222820 enp1s0 In IP DESKTOP-6P79G8T.local.44288 > chuwi.local.35623: Flags [S], seq 691695993, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:50:05.222916 enp1s0 Out IP chuwi.local.35623 > DESKTOP-6P79G8T.local.44288: Flags [R.], seq 0, ack 691695994, win 0, length 0
18:50:05.736304 enp1s0 In IP DESKTOP-6P79G8T.local.44288 > chuwi.local.35623: Flags [S], seq 691695993, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:50:05.736443 enp1s0 Out IP chuwi.local.35623 > DESKTOP-6P79G8T.local.44288: Flags [R.], seq 0, ack 1, win 0, length 0
18:50:06.257344 enp1s0 In IP DESKTOP-6P79G8T.local.44288 > chuwi.local.35623: Flags [S], seq 691695993, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:50:06.257479 enp1s0 Out IP chuwi.local.35623 > DESKTOP-6P79G8T.local.44288: Flags [R.], seq 0, ack 1, win 0, length 0
18:50:06.773077 enp1s0 In IP DESKTOP-6P79G8T.local.44288 > chuwi.local.35623: Flags [S], seq 691695993, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:50:06.773168 enp1s0 Out IP chuwi.local.35623 > DESKTOP-6P79G8T.local.44288: Flags [R.], seq 0, ack 1, win 0, length 0
18:50:07.300299 enp1s0 In IP DESKTOP-6P79G8T.local.44288 > chuwi.local.35623: Flags [S], seq 691695993, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
18:50:07.300423 enp1s0 Out IP chuwi.local.35623 > DESKTOP-6P79G8T.local.44288: Flags [R.], seq 0, ack 1, win 0, length 0
18:50:23.044425 enp1s0 B IP DESKTOP-6P79G8T.local.35623 > 255.255.255.255.35622: UDP, length 1
^C
41 packets captured
42 packets received by filter
0 packets dropped by kernel
Client local Firewall:
$ sudo ufw status verbose
Status: active
Logging: on (low)
Default: deny (incoming), allow (outgoing), deny (routed)
New profiles: skip
To Action From
80,443/tcp (Nginx Full) ALLOW IN Anywhere
55413/tcp ALLOW IN Anywhere
55414/tcp ALLOW IN Anywhere
55415/tcp ALLOW IN Anywhere
35623/tcp ALLOW IN Anywhere
35622/udp ALLOW IN Anywhere
7655/tcp ALLOW IN Anywhere
80,443/tcp (Nginx Full (v6)) ALLOW IN Anywhere (v6)
55413/tcp (v6) ALLOW IN Anywhere (v6)
55414/tcp (v6) ALLOW IN Anywhere (v6)
55415/tcp (v6) ALLOW IN Anywhere (v6)
35623/tcp (v6) ALLOW IN Anywhere (v6)
35622/udp (v6) ALLOW IN Anywhere (v6)
7655/tcp (v6) ALLOW IN Anywhere (v6)
Problem Description:
When I attempt to connect from the Windows server to the Linux client, the connections fail. Using Test-NetConnection from PowerShell on the Windows server indicates that all attempts to the client’s ports are unsuccessful (i.e., TcpTestSucceeded is False). Despite the client machine’s firewall rules allowing the necessary TCP and UDP ports, the server cannot establish a connection.
Technical Details:
- The UrBackup client is configured to listen on
127.0.0.1and[::1], which I realized limits it to localhost connections. This setup prevents the server from communicating with the client. - When checked with
ss -tulnp, it confirms that the client is listening only on localhost for both IPv4 and IPv6. - Firewall settings on the client (managed via UFW) are properly configured to allow inbound connections on the required UrBackup ports (55413, 55414, 55415 for TCP and 35623, 35622 for UDP).
Attempts to Resolve:
- I tried modifying the client configuration to listen on all interfaces by changing
127.0.0.1to0.0.0.0and[::1]to[::], but how?
Does anyone have suggestions on how I might resolve this issue or further steps I can take to diagnose and address this problem effectively? Any advice on how to make the client accept external connections would be greatly appreciated.
I attach some screenshots, mybe it helps
Logs are empty:
I try also from Server:
$ sudo urbackupclientctl start --full
Error starting backup. No backup server found.
Thank you for any help you can provide!
