I have 5 clients running windows 8.1 pro in my domain network
the clients backup to a share on the network
for the last week they have been failing instantly when i run a full file backup or an incremental file backup
Connecting to ClientService of “Dennis” failed - CONNECT error during filelist construction
i have made sure clients are running on machine and they say they are connected to the server
uroni
2
This error occurs, if the server cannot connect to TCP port 35623 of the clients. Maybe the firewall config changed? See http://www.urbackup.org/administration_manual.html#x1-720009.3 for the used ports.
thanks for the advice, i have firewall disabled all together, which should allow any connection
i rebooted the server and still get the same error
anything else that could cause it ?
uroni
4
Did you disable the client or server firewall?
Do you have a solution for the issue?
