Connect clients with a HTTPS CONNECT web proxy
Originally published at: http://blog.urbackup.org/299/connect-clients-with-a-https-connect-web-proxy
With 2.4.x you can use UrBackup with a HTTPS proxy. This way you can have the web interface and the clients connecting at the same port, secured by the same transport encryption (SSL). This post shows how to do this in combination with the Apache web server. The idea is that the client connects to…
Be aware things changed in Version 2.5.
