For one system I always get this error message on file backups (incremental and full):
2017-11-14 15:40:54(error): Error saving metadata. Common metadata size could not be read.
2017-11-14 15:40:54(info): Copied metadata to /tmp/cps.lrF4x1 for error analysis
UrBackup Server 2.1.19 on Ubuntu 16.04, Client 2.1.16 on Windows 8.1
I don’t really know where to start searching…
Thanks,
K0n24d
EDIT: found some extra info in the realtime log:
14/11/17 15:40 DEBUG Metadata of "ErrorInfo.ini" is missing
14/11/17 15:40 DEBUG Metadata of "summary.log" is missing
14/11/17 15:40 DEBUG Metadata of "20140816_141037_install.log" is missing
14/11/17 15:40 DEBUG Metadata of "Royalty.ini" is missing
14/11/17 15:40 DEBUG Metadata of "SRExport.ini" is missing
14/11/17 15:40 DEBUG Metadata of ".." missing
14/11/17 15:40 DEBUG Metadata of "regid.1991-06.com.microsoft Microsoft Office Professional Plus 2013.swidtag" is missing
14/11/17 15:40 DEBUG Metadata of "regid.1991-06.com.microsoft_Windows-8.1-Pro.swidtag" is missing
14/11/17 15:40 DEBUG Metadata of ".symlink_java.exe" is missing
14/11/17 15:40 DEBUG Metadata of ".symlink_javaw.exe" is missing
14/11/17 15:40 DEBUG Metadata of ".symlink_javaws.exe" is missing
14/11/17 15:40 DEBUG Some metadata was missing
14/11/17 15:40 DEBUG Syncing file system...
14/11/17 15:40 INFO Transferred 64.0017 GB - Average speed: 74.8309 MBit/s
14/11/17 15:40 DEBUG Script does not exist urbackup/post_full_filebackup
14/11/17 15:41 INFO Time taken for backing up client XXXXXXXXX: 2h 4m 3s
14/11/17 15:41 INFO Backup completed with issues
But looking at the file content and the messages I was thinking that this file is rather a dump of the metadata of the files in the backup and not a file we could not get the metadata for.
Not sure this phrase is understandable by someone else
I thought theses were temp files so i never payed any real attention, but yes i also have a bunch of /tmp/cps* files on my clients. However i can t find the same error message in the client logs.
at home it s like 3 files in 2 hours
on the home server(it runs both a urbackup client and server) it s 1712 since 30 april , so maybe some cleanup is needed
I must admit that given the content of the file, I feel a little bit uncomfortable sending it out. Is there a way to only extract what you’re interested in? (I do know this might be a complicated question…)
By the way, I “solved” the issue by excluding the AppData folders from the file backups. This was not really of interest anyway for our file backups.
If you want to you can then probably track it down to some specific file(s) and only send that metadata file (or tell me what’s different with those file(s)).
