Dear friend
did any one have a solution for this error
service ‘urbackup client service for backups’ (urbackupclientbackend) failed to start .
verify that you have sufficient privileges to start system service
Dear friend
Did you install the required Visual Studio Runtimes?
no but the app work on some of our PC and not at all of them
at the same domain with same updates and configuration
but i will try to check the visual studio run-times
The update is required to run Urbackup Services.
Some Programs bring this update with them, others dont.
Thats why i roll it out, bundled with the update.
Maybe the PCs who work, already have the update installed by some other software - try it out
oh and the Visual Studio update is only required for windows 8.1 and below. 10 already got it onboard.
For windows 7 it should be this update: https://www.microsoft.com/en-us/download/details.aspx?id=49077
thanks a lot
its worked …appreciate your support
