Is it possible to setup as Storage folder a cloud storage? F.e. Google?
If you can expose it as drive, yes. On Linux for example via S3QL https://code.google.com/p/s3ql/ or S3Backer https://code.google.com/p/s3backer/
You could have your UrBackup “output” directory on your local computer, and that directory as the “input” directory to Cryptmator (an encryption program specifically designed for cloud storage), and Cryptomator’s “output” directory as the “input” directory to your cloud sync client, with your cloud client set to automatically sync.
I would definitely recommend encrypting your backups on your local end, under your exclusive control, and not trusting the encryption that is available from cloud providers.
