Clients rights
Question as of now is there anyway to limit a client options in the settings menu via the web UI. If I give them access to the web UI settings under there login they can go in and change any settings I set such as me limiting there computer to only have 100GB of disk space. I could just take settings away but then they would have to send me a request for me to change there passwords even if they know there current password. So my question is can I only allow them to see change my password under the settings options?
You are right, that is not optimal. I changed it.
did you change it on a newer version?
Yes, in 1.3 there is a new right “client_settings”, which when removed does not allow the user to change any settings, but still set the user password.
I also moved the default user rights to default_user_rights.js (in the urbackup/www folder) to allow make it more easy to change the initial rights.
