Clients I want to remove get not removed while cleanup backup window. For days now the Clients state “This client is going to be removed. Stop removing client. Clients are removed during the cleanup time window, if they are offline.” but still are there, in statistics I see 0 Bytes backup. Bug?
I have a similar problem. On a client machine I had uninstalled the UrBackup manually via add/remove programs (she had an old version) and now the Dashboard says “client will be removed” but it does not ever go away. Can it be manually removed somehow?
I didn’t want to wait for the cleanup cycle. I was hoping there was a “faster” or immediate way to remove them. In any case, I just cancelled the removal and manually reinstalled the client and it somehow re-linked itself and started working again. So I am ok!
Repair said [quote=""]Stopping UrBackup Server…
2013-06-03 19:11:34: Created new database connection for urbackup/backup_server.db
2013-06-03 19:11:34: Exporting main database…
2013-06-03 19:25:07: Created new database connection for urbackup/backup_server_settings.db
2013-06-03 19:25:07: Exporting settings database…
2013-06-03 19:25:07: Destroying all databases…
2013-06-03 19:25:09: Created new database connection for urbackup/backup_server.db
2013-06-03 19:25:09: Importing main database…
2013-06-03 19:34:13: Created new database connection for urbackup/backup_server_settings.db
2013-06-03 19:34:13: Importing settings database…
2013-06-03 19:34:13: Completed sucessfully.
Starting UrBackup Server…
UrBackup Windows Server wird gestartet…
UrBackup Windows Server wurde erfolgreich gestartet.
[/quote] but after that the web interface only states “loading” and neither login nor summary or anything else comes up. Seems “repair” did completely destroy it instead of what it should do
Yes I have, of course. I activated shadow copies for sure. But what about how to go on solving this issue? Removing of the clients also missed, of course.
that´s a bit difficult since backing up still worked and now I have a damaged database backups since days or weeks. How can I start up with a new empty database regarding the backups but keep all my settings for clients?
You could export some of the tables (e.g. the “clients” table via sqlite3 .dump, i.e., .output clients.sql .dump clients). Remove/rename the two databases. Restart the service, to make it recreate new databases. Replace the backup_server_settings.db with the old db and import the exported tables (from the .sql files) from the old backup_server.db.
PS: but now when I want to cleanup database using cleanup.bat I get the following output:
UrBackup Windows Server wurde erfolgreich beendet.
“Cleanup amount ‘’”
2013-06-17 12:21:47: Shutting down all database instances…
2013-06-17 12:21:47: Destroying all databases…
2013-06-17 12:21:47: Opening urbackup server database…
2013-06-17 12:21:47: ERROR: Error preparing Query [PRAGMA synchronous=NORMAL]: disk I/O error
2013-06-17 12:21:47: ERROR: Error in CQuery::Execute - disk I/O error Stmt: [ATTACH DATABASE ‘urbackup/backup_server_settings.db’ AS settings_db]
2013-06-17 12:21:47: ERROR: SQL: disk I/O error Stmt: [ATTACH DATABASE ‘urbackup/backup_server_settings.db’ AS settings_db]
2013-06-17 12:21:47: Created new database connection for urbackup/backup_server.db
2013-06-17 12:21:47: ERROR: Error preparing Query [SELECT value FROM settings_db.settings WHERE key=?]: disk I/O error
2013-06-17 12:21:47: Testing if backup destination can handle subvolumes and snapshots…
2013-06-17 12:21:56: ERROR: Fatal exception. Crash dump written to “C:\Users\JO3498~1.MUE\AppData\Local\Temp\UrBackup\v0.25.1-20130617-122148-4684-2700.dmp”[/quote]
