Hey UrBackup-Community,
I have problems regarding my UrBackup server running in a local network. On the same machine I installed a client in order to back it up (64-bit Debian). Because of some problems I had to re-add the client.
So I removed the client and tried to re-add it. But now the status of the client stays in “internet_status” = “wait_local” (switches to “no_server” after some minutes) and “internet_connected” = false.
It seems like the client is blacklisted after being removed.
Flushing the database didn’t help.
How can I re-add the client running on the same machine?
The “add client” function doesn’t work and the client is not discovered by the server.
Is there a way to manually add the client? Or can I “unblock” the client?
The server client says:
2018-09-14 15:46:25: ERROR: urbackupserver: Failed binding socket to port 35623. Another instance of this application may already be active and bound to this port.
2018-09-14 15:46:25: ERROR: Binding tcp socket to port 35621 failed. Another instance of this application may already be active and bound to this port.
But I’m not sure if it is related to my problem.
Also the log is spammed with these error messages:
2018-09-11 21:36:47: ERROR: Token id for group “staff” not found
2018-09-11 21:36:47: ERROR: Token id for group “games” not found
2018-09-11 21:36:47: ERROR: Token id for group “users” not found
2018-09-11 21:36:47: ERROR: Token id for group “nogroup” not found
2018-09-11 21:36:47: ERROR: Token id for group “systemd-journal” not found
2018-09-11 21:36:47: ERROR: Token id for group “systemd-timesync” not found
2018-09-11 21:36:47: ERROR: Token id for group “systemd-network” not found
2018-09-11 21:36:47: ERROR: Token id for group “systemd-resolve” not found
2018-09-11 21:36:47: ERROR: Token id for group “systemd-bus-proxy” not found
2018-09-11 21:36:47: ERROR: Token id for group “input” not found
2018-09-11 21:36:47: ERROR: Token id for group “crontab” not found
2018-09-11 21:36:47: ERROR: Token id for group “Debian-exim” not found
2018-09-11 21:36:47: ERROR: Token id for group “messagebus” not found
2018-09-11 21:36:47: ERROR: Token id for group “ssh” not found
2018-09-11 21:36:47: ERROR: Token id for group “ssl-cert” not found
2018-09-11 21:36:47: ERROR: Token id for group “postfix” not found
2018-09-11 21:36:47: ERROR: Token id for group “postdrop” not found
2018-09-11 21:36:47: ERROR: Token id for group “rdma” not found
2018-09-11 21:36:47: ERROR: Token id for group “ceph” not found
2018-09-11 21:36:47: ERROR: Token id for group “ntp” not found
But these messages don’t occur right now. They happened 3 days ago…
These messages also appear multiple times in the log:
2018-09-14 16:11:42: ERROR: Error getting Client settings of MBP.localdomain. Errorcode: BASE_DIR_LOST (7)
2018-09-14 16:11:42: ERROR: Getting client settings failed -2
I think these messages occur because the client is listed in the web-interface but the client is not even installed on the machine (MBP.localdomain).
These are my versions:
root@vhost:~# urbackupclientbackend --version
UrBackup Client Backend v2.2.6.0
Copyright © 2011-2018 Martin Raiber
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
root@vhost:~# urbackupsrv --version
UrBackup Server v2.2.11.0
Is there a possibility to completely un-install both - the client and server and re-install it completely fresh? So it also can be configured from start of.
It’s really frustrating and pretty complicated if you’re not too deep in development and administration.
I hope you can help me!
Greetings,
Luca
