Strange behavior I’ve been dealing with for a month or so. Client log shows nothing special, file list was being constructed (I assume “Final path:” is that?), then it just stops.
Server side config doesn’t show anything either, server was busy backing a different client and didn’t even mention the crashed one.
Versions 2.1.3 on both client and server, CentOS 7 on server, CentOS 6 on client. The fact that the client is a VM on the server might be of note.
Error that I get in the log is
2016-10-22 02:02:55(info): Starting incremental file backup...
2016-10-22 02:03:35(error): Constructing of filelist of "name" failed - TIMEOUT(1)
2016-10-22 02:03:35(error): Backup had an early error. Deleting partial backup.
2016-10-22 01:03:15: Looking for old Sessions... 0 sessions
2016-10-22 01:33:15: Looking for old Sessions... 0 sessions
2016-10-22 02:02:55: Final path: /etc
2016-10-22 02:02:55: Final path: /var/www
2016-10-22 02:02:55: Final path: /var/named
2016-10-22 02:02:55: Final path: /home/backup/wp-db-daily.gz
2016-10-22 02:02:55: Final path: /tmp/backup
2016-10-22 02:02:55: Final path: /usr/share/icons/hicolor/16x16/apps/system-logo-icon.png
2016-10-22 02:02:55: Final path: /boot/grub/grub.conf
2016-10-22 02:02:55: Final path: /usr/share/zoneinfo/Europe/Vilnius
2016-10-22 02:02:55: Final path: /usr/share/fonts/default/ghostscript
2016-10-22 02:02:55: Final path: /usr/share/fonts/default/Type1
2016-10-22 02:02:55: Final path: /usr/share/fonts/liberation
2016-10-22 02:02:55: Final path: /usr/share/X11/fonts/100dpi
2016-10-22 02:02:55: Final path: /usr/share/X11/fonts/Type1
2016-10-22 02:02:55: Final path: /usr/share/X11/fonts/misc
2016-10-22 02:02:55: Final path: /sbin/iptables-multi-1.4.7
2016-10-22 02:02:55: Final path: /usr/bin/wodim
2016-10-22 02:02:55: Final path: /usr/share/man/man1/wodim.1.gz
2016-10-22 02:02:55: Final path: /usr/bin/readom
2016-10-22 02:02:55: Final path: /usr/share/man/man1/readom.1.gz
2016-10-22 02:02:55: Final path: /sbin/ip6tables-multi-1.4.7
2016-10-22 02:02:55: Final path: /lib/libip4tc.so.0.0.0-1.4.7
2016-10-22 02:02:55: Final path: /lib/libip6tc.so.0.0.0-1.4.7
2016-10-22 02:02:55: Final path: /lib/libipq.so.0.0.0-1.4.7
2016-10-22 02:02:55: Final path: /lib/libiptc.so.0.0.0-1.4.7
2016-10-22 02:02:55: Final path: /usr/lib/nss/libnssckbi.so
2016-10-22 02:02:55: Final path: /lib/libxtables.so.4.0.0-1.4.7
2016-10-22 02:02:55: Final path: /usr/bin/elinks
2016-10-22 02:02:55: Final path: /usr/share/man/man1/elinks.1.gz
2016-10-22 02:02:55: Final path: /bin/mailx
2016-10-22 02:02:55: Final path: /usr/share/man/man1/mailx.1.gz
2016-10-22 02:02:55: Final path: /usr/share/man/man8/ip6tables-restore-1.4.7.8.gz
2016-10-22 02:02:55: Final path: /usr/share/man/man8/ip6tables-save-1.4.7.8.gz
2016-10-22 02:02:55: Final path: /usr/share/man/man8/ip6tables-1.4.7.8.gz
2016-10-22 02:02:55: Final path: /usr/share/man/man8/iptables-restore-1.4.7.8.gz
2016-10-22 02:02:55: Final path: /usr/share/man/man8/iptables-save-1.4.7.8.gz
2016-10-22 02:02:55: Final path: /usr/share/man/man8/iptables-xml-1.4.7.8.gz
2016-10-22 02:02:55: Final path: /usr/share/man/man8/iptables-1.4.7.8.gz
2016-10-22 02:02:55: Final path: /usr/bin/genisoimage
2016-10-22 02:02:55: Final path: /usr/share/man/man1/genisoimage.1.gz
2016-10-22 02:02:55: Final path: /usr/sbin/sendmail.postfix
2016-10-22 02:02:55: Final path: /usr/share/man/man5/aliases.postfix.5.gz
2016-10-22 02:02:55: Final path: /usr/share/man/man1/mailq.postfix.1.gz
2016-10-22 02:02:55: Final path: /usr/share/man/man1/newaliases.postfix.1.gz
2016-10-22 02:02:55: Final path: /usr/bin/rmail.postfix
2016-10-22 02:02:55: Final path: /usr/share/man/man1/sendmail.postfix.1.gz
2016-10-22 02:02:55: Final path: /usr/bin/lpr.cups
2016-10-22 02:02:55: Final path: /usr/bin/cancel.cups
2016-10-22 02:02:55: Final path: /usr/share/man/man1/cancel-cups.1.gz
2016-10-22 02:02:55: Final path: /usr/bin/lp.cups
2016-10-22 02:02:55: Final path: /usr/sbin/lpc.cups
2016-10-22 02:02:55: Final path: /usr/share/man/man8/lpc-cups.8.gz
2016-10-22 02:02:55: Final path: /usr/share/man/man1/lp-cups.1.gz
2016-10-22 02:02:55: Final path: /usr/bin/lpq.cups
2016-10-22 02:02:55: Final path: /usr/share/man/man1/lpq-cups.1.gz
2016-10-22 02:02:55: Final path: /usr/bin/lprm.cups
2016-10-22 02:02:55: Final path: /usr/share/man/man1/lpr-cups.1.gz
2016-10-22 02:02:55: Final path: /usr/share/man/man1/lprm-cups.1.gz
2016-10-22 02:02:55: Final path: /usr/bin/lpstat.cups
2016-10-22 02:02:55: Final path: /usr/share/man/man1/lpstat-cups.1.gz
2016-10-22 02:02:55: Final path: /usr/share/fontconfig/conf.avail/20-unhint-small-dejavu-sans.conf
2016-10-22 02:02:55: Final path: /usr/share/fontconfig/conf.avail/57-dejavu-sans.conf
2016-10-22 02:02:55: Final path: /var/log/httpd
2016-10-22 02:02:55: Final path: /usr/lib/httpd/modules
2016-10-22 02:02:55: Final path: /var/run/httpd
2016-10-22 02:02:55: Final path: /usr/share/pki/ca-trust-legacy/ca-bundle.legacy.default.crt
2016-10-22 02:02:55: Final path: /sbin/ifdown
2016-10-22 02:02:55: Final path: /sbin/ifup
2016-10-22 02:02:55: Final path: /usr/share/pixmaps/poweredby.png
2016-10-22 02:02:55: Script list at "/usr/local/etc/urbackup/scripts/list" does not exist. Skipping.
2016-10-22 02:03:17: Looking for old Sessions... 0 sessions
2016-10-22 02:03:34: Script "/usr/local/etc/urbackup/prefilebackup" returned with success
2016-10-22 02:03:34: Backup dir missing, creating new
2016-10-22 02:03:34: Processing /var/named
2016-10-22 02:03:34: Stripping first slash
2016-10-22 02:03:34: Replacing slashes with dashes
2016-10-22 02:03:34: Result is var-named
2016-10-22 02:03:34: Ready to go
2016-10-22 02:03:34: Creating backup of /var/named
2016-10-22 02:03:34: tar: Removing leading `/' from member names
2016-10-22 02:03:34: Processing /var/www
2016-10-22 02:03:34: Result is var-www
2016-10-22 02:03:34: Creating backup of /var/www
2016-10-22 02:03:34: Processing /etc
2016-10-22 02:03:34: Result is etc
2016-10-22 02:03:34: Creating backup of /etc
2016-10-22 02:03:34: tar: Removing leading `/' from hard link targets
2016-10-22 02:03:34: Final path: /etc
2016-10-22 02:03:34: Final path: /var/www
2016-10-22 02:03:34: Final path: /var/named
2016-10-22 02:03:34: Final path: /home/backup/wp-db-daily.gz
2016-10-22 02:03:34: Final path: /tmp/backup
2016-10-22 02:03:34: Final path: /usr/share/icons/hicolor/16x16/apps/system-logo-icon.png
2016-10-22 02:03:34: Final path: /boot/grub/grub.conf
2016-10-22 02:03:34: Final path: /usr/share/zoneinfo/Europe/Vilnius
2016-10-22 02:03:34: Final path: /usr/share/fonts/default/ghostscript
2016-10-22 02:03:34: Final path: /usr/share/fonts/default/Type1
2016-10-22 02:03:34: Final path: /usr/share/fonts/liberation
2016-10-22 02:03:34: Final path: /usr/share/X11/fonts/100dpi
2016-10-22 02:03:34: Final path: /usr/share/X11/fonts/Type1
2016-10-22 02:03:34: Final path: /usr/share/X11/fonts/misc
2016-10-22 02:03:34: Final path: /sbin/iptables-multi-1.4.7
2016-10-22 02:03:34: Final path: /usr/bin/wodim
2016-10-22 02:03:34: Final path: /usr/share/man/man1/wodim.1.gz
2016-10-22 02:03:34: Final path: /usr/bin/readom
2016-10-22 02:03:34: Final path: /usr/share/man/man1/readom.1.gz
2016-10-22 02:03:34: Final path: /sbin/ip6tables-multi-1.4.7
2016-10-22 02:03:34: Final path: /lib/libip4tc.so.0.0.0-1.4.7
2016-10-22 02:03:34: Final path: /lib/libip6tc.so.0.0.0-1.4.7
2016-10-22 02:03:34: Final path: /lib/libipq.so.0.0.0-1.4.7
2016-10-22 02:03:34: Final path: /lib/libiptc.so.0.0.0-1.4.7
2016-10-22 02:03:34: Final path: /usr/lib/nss/libnssckbi.so
2016-10-22 02:03:34: Final path: /lib/libxtables.so.4.0.0-1.4.7
2016-10-22 02:03:34: Final path: /usr/bin/elinks
2016-10-22 02:03:34: Final path: /usr/share/man/man1/elinks.1.gz
2016-10-22 02:03:34: Final path: /bin/mailx
2016-10-22 02:03:34: Final path: /usr/share/man/man1/mailx.1.gz
2016-10-22 02:03:34: Final path: /usr/share/man/man8/ip6tables-restore-1.4.7.8.gz
2016-10-22 02:03:34: Final path: /usr/share/man/man8/ip6tables-save-1.4.7.8.gz
2016-10-22 02:03:34: Final path: /usr/share/man/man8/ip6tables-1.4.7.8.gz
2016-10-22 02:03:34: Final path: /usr/share/man/man8/iptables-restore-1.4.7.8.gz
2016-10-22 02:03:34: Final path: /usr/share/man/man8/iptables-save-1.4.7.8.gz
2016-10-22 02:03:34: Final path: /usr/share/man/man8/iptables-xml-1.4.7.8.gz
2016-10-22 02:03:34: Final path: /usr/share/man/man8/iptables-1.4.7.8.gz
2016-10-22 02:03:34: Final path: /usr/bin/genisoimage
2016-10-22 02:03:34: Final path: /usr/share/man/man1/genisoimage.1.gz
2016-10-22 02:03:34: Final path: /usr/sbin/sendmail.postfix
2016-10-22 02:03:34: Final path: /usr/share/man/man5/aliases.postfix.5.gz
2016-10-22 02:03:34: Final path: /usr/share/man/man1/mailq.postfix.1.gz
2016-10-22 02:03:34: Final path: /usr/share/man/man1/newaliases.postfix.1.gz
2016-10-22 02:03:34: Final path: /usr/bin/rmail.postfix
2016-10-22 02:03:34: Final path: /usr/share/man/man1/sendmail.postfix.1.gz
2016-10-22 02:03:34: Final path: /usr/bin/lpr.cups
2016-10-22 02:03:34: Final path: /usr/bin/cancel.cups
2016-10-22 02:03:34: Final path: /usr/share/man/man1/cancel-cups.1.gz
2016-10-22 02:03:34: Final path: /usr/bin/lp.cups
2016-10-22 02:03:34: Final path: /usr/sbin/lpc.cups
2016-10-22 02:03:34: Final path: /usr/share/man/man8/lpc-cups.8.gz
2016-10-22 02:03:34: Final path: /usr/share/man/man1/lp-cups.1.gz
2016-10-22 02:03:34: Final path: /usr/bin/lpq.cups
2016-10-22 02:03:34: Final path: /usr/share/man/man1/lpq-cups.1.gz
2016-10-22 02:03:34: Final path: /usr/bin/lprm.cups
2016-10-22 02:03:34: Final path: /usr/share/man/man1/lpr-cups.1.gz
2016-10-22 02:03:34: Final path: /usr/share/man/man1/lprm-cups.1.gz
2016-10-22 02:03:34: Final path: /usr/bin/lpstat.cups
2016-10-22 02:03:34: Final path: /usr/share/man/man1/lpstat-cups.1.gz
2016-10-22 02:03:34: Final path: /usr/share/fontconfig/conf.avail/20-unhint-small-dejavu-sans.conf
2016-10-22 02:03:34: Final path: /usr/share/fontconfig/conf.avail/57-dejavu-sans.conf
2016-10-22 02:03:34: Final path: /var/log/httpd
2016-10-22 02:03:34: Final path: /usr/lib/httpd/modules
2016-10-22 02:03:34: Final path: /var/run/httpd
2016-10-22 02:03:34: Final path: /usr/share/pki/ca-trust-legacy/ca-bundle.legacy.default.crt
2016-10-22 02:03:34: Final path: /sbin/ifdown
2016-10-22 02:03:34: Final path: /sbin/ifup
2016-10-22 02:03:34: Final path: /usr/share/pixmaps/poweredby.png
I assume that at this point the client crashed. Is there anything else I can find on my machine?
2016-11-04 12:24:11: rc=0 hasError=true state=0
2016-11-04 12:24:11: Internet mode not enabled
2016-11-04 12:24:21: FileSrv: ClientThread deleted. 1024 KB Memory freed.
2016-11-04 12:24:21: FileSrv: Stopping CUPDThread…
2016-11-04 12:24:21: CUDPThread exited.
2016-11-04 12:24:21: FileSrv: Binding UDP socket at port 35622…
2016-11-04 12:24:21: FileSrv: done.
2016-11-04 12:24:21: FileSrv: Servername: -SERVERNAME-
2016-11-04 12:24:21: FileSrv: Server started up successfully
2016-11-04 12:24:21: FileSrv: UDP Thread startet
2016-11-04 12:24:21: Final path: /etc
2016-11-04 12:24:21: Final path: /var/www
2016-11-04 12:24:21: Final path: /var/named
2016-11-04 12:24:21: Final path: /home/backup/wp-db-daily.gz
2016-11-04 12:24:21: Final path: /tmp/backup
2016-11-04 12:24:21: Final path: /usr/share/icons/hicolor/16x16/apps/system-logo-icon.png
2016-11-04 12:24:21: Final path: /boot/grub/grub.conf
2016-11-04 12:24:21: Final path: /usr/share/zoneinfo/Europe/Vilnius
2016-11-04 12:24:21: Final path: /usr/share/fonts/default/ghostscript
2016-11-04 12:24:21: Final path: /usr/share/fonts/default/Type1
2016-11-04 12:24:21: Final path: /usr/share/fonts/liberation
2016-11-04 12:24:21: Final path: /usr/share/X11/fonts/100dpi
2016-11-04 12:24:21: Final path: /usr/share/X11/fonts/Type1
2016-11-04 12:24:21: Final path: /usr/share/X11/fonts/misc
2016-11-04 12:24:21: Final path: /sbin/iptables-multi-1.4.7
2016-11-04 12:24:21: Final path: /usr/bin/wodim
2016-11-04 12:24:21: Final path: /usr/share/man/man1/wodim.1.gz
2016-11-04 12:24:21: Final path: /usr/bin/readom
2016-11-04 12:24:21: Final path: /usr/share/man/man1/readom.1.gz
2016-11-04 12:24:21: Final path: /sbin/ip6tables-multi-1.4.7
2016-11-04 12:24:21: Final path: /lib/libip4tc.so.0.0.0-1.4.7
2016-11-04 12:24:21: Final path: /lib/libip6tc.so.0.0.0-1.4.7
2016-11-04 12:24:21: Final path: /lib/libipq.so.0.0.0-1.4.7
2016-11-04 12:24:21: Final path: /lib/libiptc.so.0.0.0-1.4.7
2016-11-04 12:24:21: Final path: /usr/lib/nss/libnssckbi.so
2016-11-04 12:24:21: Final path: /lib/libxtables.so.4.0.0-1.4.7
2016-11-04 12:24:21: Final path: /usr/bin/elinks
2016-11-04 12:24:21: Final path: /usr/share/man/man1/elinks.1.gz
2016-11-04 12:24:21: Final path: /bin/mailx
2016-11-04 12:24:21: Final path: /usr/share/man/man1/mailx.1.gz
2016-11-04 12:24:21: Final path: /usr/share/man/man8/ip6tables-restore-1.4.7.8.gz
2016-11-04 12:24:21: Final path: /usr/share/man/man8/ip6tables-save-1.4.7.8.gz
2016-11-04 12:24:21: Final path: /usr/share/man/man8/ip6tables-1.4.7.8.gz
2016-11-04 12:24:21: Final path: /usr/share/man/man8/iptables-restore-1.4.7.8.gz
2016-11-04 12:24:21: Final path: /usr/share/man/man8/iptables-save-1.4.7.8.gz
2016-11-04 12:24:21: Final path: /usr/share/man/man8/iptables-xml-1.4.7.8.gz
2016-11-04 12:24:21: Final path: /usr/share/man/man8/iptables-1.4.7.8.gz
2016-11-04 12:24:21: Final path: /usr/bin/genisoimage
2016-11-04 12:24:21: Final path: /usr/share/man/man1/genisoimage.1.gz
2016-11-04 12:24:21: Final path: /usr/sbin/sendmail.postfix
2016-11-04 12:24:21: Final path: /usr/share/man/man5/aliases.postfix.5.gz
2016-11-04 12:24:21: Final path: /usr/share/man/man1/mailq.postfix.1.gz
2016-11-04 12:24:21: Final path: /usr/share/man/man1/newaliases.postfix.1.gz
2016-11-04 12:24:21: Final path: /usr/bin/rmail.postfix
2016-11-04 12:24:21: Final path: /usr/share/man/man1/sendmail.postfix.1.gz
2016-11-04 12:24:21: Final path: /usr/bin/lpr.cups
2016-11-04 12:24:21: Final path: /usr/bin/cancel.cups
2016-11-04 12:24:21: Final path: /usr/share/man/man1/cancel-cups.1.gz
2016-11-04 12:24:21: Final path: /usr/bin/lp.cups
2016-11-04 12:24:21: Final path: /usr/sbin/lpc.cups
2016-11-04 12:24:21: Final path: /usr/share/man/man8/lpc-cups.8.gz
2016-11-04 12:24:21: Final path: /usr/share/man/man1/lp-cups.1.gz
2016-11-04 12:24:21: Final path: /usr/bin/lpq.cups
2016-11-04 12:24:21: Final path: /usr/share/man/man1/lpq-cups.1.gz
2016-11-04 12:24:21: Final path: /usr/bin/lprm.cups
2016-11-04 12:24:21: Final path: /usr/share/man/man1/lpr-cups.1.gz
2016-11-04 12:24:21: Final path: /usr/share/man/man1/lprm-cups.1.gz
2016-11-04 12:24:21: Final path: /usr/bin/lpstat.cups
2016-11-04 12:24:21: Final path: /usr/share/man/man1/lpstat-cups.1.gz
2016-11-04 12:24:21: Final path: /usr/share/fontconfig/conf.avail/20-unhint-small-dejavu-sans.conf
2016-11-04 12:24:21: Final path: /usr/share/fontconfig/conf.avail/57-dejavu-sans.conf
2016-11-04 12:24:21: Final path: /var/log/httpd
2016-11-04 12:24:21: Final path: /usr/lib/httpd/modules
2016-11-04 12:24:21: Final path: /var/run/httpd
2016-11-04 12:24:21: Final path: /usr/share/pki/ca-trust-legacy/ca-bundle.legacy.default.crt
2016-11-04 12:24:21: Final path: /sbin/ifdown
2016-11-04 12:24:21: Final path: /sbin/ifup
2016-11-04 12:24:21: Final path: /usr/share/pixmaps/poweredby.png
2016-11-04 12:25:11: ClientService cmd: PONG
2016-11-04 12:26:07: Internet mode not enabled
2016-11-04 12:26:11: ClientService cmd: PONG
Issued full file backup, went successfully with this at the end, not sure if valuable:
0-1478255540-Transferred 2.21049 GB - Average speed: 120.326 MBit/s
0-1478255547-Time taken for backing up client SERVERNAME: 3m 30s
0-1478255547-Backup succeeded
2016-11-04 12:32:29: rc=0 hasError=true state=0
2016-11-04 12:32:38: FileSrv: ClientThread deleted. 1024 KB Memory freed.
2016-11-04 12:32:38: FileSrv: Stopping CUPDThread…
2016-11-04 12:32:38: CUDPThread exited.
[Thread 0xb7afdb70 (LWP 29429) exited]
[Thread 0xb77ffb70 (LWP 29430) exited]
2016-11-04 12:32:39: FileSrv: Binding UDP socket at port 35622…
2016-11-04 12:32:39: FileSrv: done.
2016-11-04 12:32:39: FileSrv: Servername: -SERVERNAME-
2016-11-04 12:32:39: FileSrv: Server started up successfully
2016-11-04 12:32:39: FileSrv: UDP Thread startet
2016-11-04 12:32:39: Final path: /etc
This goes on to list the same paths as before. Didn’t crash, so I’m unsure what to do next - should I just keep it running in debug mode like this until it does?
