Verifying archive integrity… All good.
Uncompressing UrBackup Client Installer for Linux 100%
Installation of UrBackup Client 2.5.25 to /usr/local … Proceed ? [Y/n]
Y
Uncompressing install data…
Detected Debian (derivative) system
Detected systemd
Detected architecture aarch64-linux-android
Aborted
Error running executable on this system (aarch64). Stopping installation.
A search of the forums + google gives some ideas, but none have worked out for me so far. This issue on the dietPi forums looked promising, but I think this issue has already been fixed.
Other than trying to build from source, any suggestions?
I have the server and clients on 3 other devices working well – including another arm64 device.
Thank you!
y
Detected systemd
Aborted
looked for direction to build client didnt really find anything, did find options to build server not client
go here download client tar(urbackup-client-2.5.25.tar.gz), Index of /Client/latest/
i used winscp…you could use wget
then go here UrBackup - Install UrBackup server from sources you will do similar process
extract to directory
run./configure ( it will fail but indicate that you need to use a switch to skip missing item or yo can install missing item, i just ignoree and added switches)
then run make install
after it completes do the steps to setup the systemd file
copy urbackupclientbackend-debian.service from where you extracted tar, to etc\systemd\system (you can rename this i used urbackup.service)
run systemctl enable urbackup.service
systemctl start urbackup-server
not sure if this is needbut i created , /var/ lib/ urbackup/ server_ident.key and added server ket found after clicking add client…
next run to add authorization key urbackupclientctl set-settings --name “raspberryphoto” --authkey “yourkeyhere”
restart service then add folder you wish to back up
