I’m having an issue - I think only with recent releases (it’s definitely worked before) - where the ‘Exclude from backup (with wildcards)’ setting in my Mac client is unpopulated.
I have a large File Backup exclusion list configured on my server - and no client-specific settings enabled to override it.
Any thoughts on where I should start to debug this? I’ve already tried trimming my exclusion list down massively - but still no joy.
Thanks for coming back to me on this. I don’t know if this is expected, but /Applications/UrBackup Client.app/Contents/MacOS/var/backup/data/ is not readable by my usual admin user. On looking at permissions of that area, I see this:
My-Mac:~ root# cd /Applications/UrBackup\ Client.app/Contents/MacOS/var/urbackup My-Mac:urbackup root# ls -lah total 728 drwxr-xr-x 14 root wheel 448B 29 Nov 09:32 . drwxr-xr-x 3 root wheel 96B 17 May 2018 .. -rwx------ 1 root wheel 98B 29 Nov 09:11 access_keys.properties -rwx------ 1 root wheel 80K 29 Nov 09:11 backup_client.db -rwx------ 1 root wheel 32K 29 Nov 09:15 backup_client.db-shm -rwx------ 1 root wheel 181K 30 Nov 04:19 backup_client.db-wal drwx------ 4 root wheel 128B 30 Nov 04:17 data -rwx------ 1 root wheel 0B 29 Nov 09:11 new_server_idents.txt -rw-r--r-- 1 root wheel 30B 29 Nov 09:11 pw.txt -rwx------ 1 root wheel 30B 29 Nov 09:11 pw_change.txt -rwx------ 1 root wheel 1.2K 29 Nov 09:11 server_idents.txt -rwx------ 1 root wheel 43B 29 Nov 09:11 session_idents.txt drwxr-xr-x 5 root wheel 160B 29 Nov 09:32 tokens -rw-r--r-- 1 root wheel 3B 27 Nov 18:08 version.txt
However, here’s the contents of data/settings.cfg:
This means you set the settings via client at some point. So it’ll use those unless you set it so that the client cannot change settings on the server.
Ah - right. I had set those in the past, but then turned off the individual clients’ settings in Backup Server > Settings > Clients > (client name) > uncheck Separate settings for this client.
I’ve now turned off Backup Server > Settings > Permissions > Allow client-side changing of settings - and that seems to have worked.
I had the issue with it in the past, i find it particallrly annoying to debug .
Can a hint about it be shown server side, like there is for the * for “Separate settings for this client” ?
