Client Does Not Stay Connected
I am running UrBackup Server on an HP DL380 running Ubuntu Server 26.04LTS. I have several LAN connected clients that are backing up happily, and I had my fileserver working, but I may need to tweak its settings again as it is now showing off-line. The machine I am working on now is a remote server runing tailscale (free version). I have been struggling to get it to connect and run a backup. it will show in the web ui as connected and when I select “start full file backup” it queues. All good … then it fails. I have run logs and watched the system try to connect then fail. I have run tcpdump and the client completes the three way handshake, but then sits quite until the server times out at 30 seconds and sends a fin tag.
So the last thing the server/client does is request an upgrade to the websocket and the two agree on that, but then the client sends nothing, and after 30 seconds the fin tag.
This should work, it works for the clients on my class c network, it should work for this client.
I thought maybe a mismatch in the version the web ui shows 2.5.38 and the client is 2.5.30, but the 2.5 is the same, so that shouldn’t be the issue.
Any ideas are welcome at this point.
Rod
The 30 seconds aren’t random. Once an Internet client is connected, the server pings it and closes the connection if no answer comes within 30 seconds. That’s the FIN you see. So the client either never gets that data or can’t answer it. The server log (/var/log/urbackup.log, debug level) should show “Ping timeout in InternetServiceConnector::Run” or “ISS_RECEIVE_ENDPOINT timeout” around that time. The client’s debug.log would show its side.
Since Tailscale already puts both machines on the same network, you don’t need Internet mode for this client. Add its Tailscale IP on the server’s Status page (Add new client, discover a local/passive client across networks). The server then connects to it like one of your LAN clients, on ports 35621-35623, and the Internet mode handshake is out of the picture. Tailscale’s ACLs need to allow those ports.
2.5.30 vs 2.5.38 isn’t the problem. They use the same protocol.
Thanks for the quick response. Yeah, that makes much more sense. I will give that a try and see if I can get this client connected. I will post my progress.
Again, thanks!
Rod
Thanks for the advice. So I have been beating this around for a while now. What I think is happening is that tailscale is not passing the UDP packets for discovery, so it never actually finds the client over the tailscale link.
I have reverted back to it being an internet client I get a S - S. - . handshake, I just can’t get it to complete the authentication.
running sudo tail -n 50 /var/log/urbackup.log
I got this: 2026-11-02 07:18:11: Looking for old Sessions… 0 sessions
2026-11-02 07:21:20: ISS_AUTH timeout in InternetServiceConnector::Run
and it repeats every 5 min just to remind me I haven’t conqured it yet, LOL
I have enrolled the help of Gemini, but the “A” part may be real, the “I” meh :slight_smile:
It sees this in tcpdump:
uGET /socket HTTP/1.1
Host: 100.81.26.70
Upgrade: websocket
Connection: Upgrade
Sec-WebSocket-Key: NUuylpW9xuYOKOX7e5qcrg== (the key is not the actual key)
Sec-WebSocket-Protocol: urbackup
Sec-WebSocket-Version: 13
and tells me I am missing authentication information.
Just not sure at this point what I am missing, it is still creating a tcp connection, but it hangs and drops after the 30 second timeout.
If you think I am doing something wrong in setting up the local client via tailscale, I would love to hear it. or if you know what I am doing wrong with the websocket connection the same goes.
Thanks in advance.
Rod
The GET /socket request means the client is connecting in WebSocket mode (the server address starts with ws://). The server only answers WebSocket on its web port 55414. Port 55415 expects the plain UrBackup protocol, so it waits for a login that never comes, and you get “ISS_AUTH timeout” after 30 s.
Either put just the IP (100.81.26.70) as the server address with port 55415, no ws://, or use ws://100.81.26.70:55414/socket.
About the local route: broadcasts don’t cross Tailscale, but a discovery hint is a direct UDP packet to port 35622, and that does go through. Adding the client’s 100.x IP as a discovery hint should let the server find it.
LJ_LongWing: I owe you an enormous debt! I am not an expert at this piece of software and went with an AI chatbot to help me build the system. AI did fine on the local clients, but then got in it’s fifo registers that it needed to use port 55415. By the time I reached out to this forum for help the situation was quite complicated. But with your insight, I was able to correct the several persistent references to that port and I have now had the client online for 15 min without issue and it is reporting PONG messages galore!
I now have offsite backup for my non-profit museum. This is huge and I am extremely grateful for your help.
Thank you,
Rod Hutchinson
Sussex, NB, Canada.
With all honesty, I’m also using AI to help you :slight_smile:
