Of course. Here is strace output:
execve("/usr/local/bin/urbackupclientctl", ["urbackupclientctl"], 0xffffdeca4cf8 /* 25 vars */) = 0
getpid() = 29841
mmap(NULL, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xfffcca800000
set_tid_address(0x5267e0) = 29841
faccessat(AT_FDCWD, "/dev/urandom", R_OK) = 0
futex(0x523818, FUTEX_WAKE_PRIVATE, 2147483647) = 0
getrandom("\x4a\x22\x78\xed\x28\xd3\x70\xd6\x16\x75\x89\xf0\x19\x3a\x53\x78\x9e\x5b\xed\xb5\x06\x10\x32\xf4\xcf\x21\x72\x17\xa4\xc8\x0f\xaf"..., 40, GRND_NONBLOCK) = 40
mmap(NULL, 1104, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xfffcca7f0000
prctl(PR_SET_VMA, 0, 0xfffcca7f0000, 0x450, 0x4e3406) = -1 EINVAL (Invalid argument)
sched_getscheduler(0) = 0 (SCHED_OTHER)
mmap(NULL, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xfffcca7e0000
mprotect(0xfffcca7e0000, 4096, PROT_NONE) = 0
sigaltstack({ss_sp=0xfffcca7e1000, ss_flags=0, ss_size=32768}, NULL) = 0
prctl(PR_SET_VMA, 0, 0xfffcca7e1000, 0x8000, 0x4e461d) = -1 EINVAL (Invalid argument)
mmap(NULL, 16777216, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xfffcc97e0000
mprotect(0xfffcca7b4000, 8192, PROT_READ|PROT_WRITE) = -1 EINVAL (Invalid argument)
mprotect(0x524000, 4096, PROT_READ) = -1 EINVAL (Invalid argument)
writev(2, [{iov_base="failed to make WriteProtected no"..., iov_len=55}, {iov_base="\n", iov_len=1}], 2failed to make WriteProtected nonwritable in initialize
) = 56
socket(AF_UNIX, SOCK_DGRAM|SOCK_CLOEXEC|SOCK_NONBLOCK, 0) = 3
connect(3, {sa_family=AF_UNIX, sun_path="/dev/socket/logdw"}, 110) = -1 ENOENT (No such file or directory)
close(3) = 0
writev(2, [{iov_base="libc", iov_len=4}, {iov_base=": ", iov_len=2}, {iov_base="failed to make WriteProtected no"..., iov_len=55}, {iov_base="\n", iov_len=1}], 4libc: failed to make WriteProtected nonwritable in initialize
) = 62
mmap(NULL, 80, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xfffcc97d0000
prctl(PR_SET_VMA, 0, 0xfffcc97d0000, 0x50, 0x4dec43) = -1 EINVAL (Invalid argument)
rt_sigprocmask(SIG_SETMASK, ~[ABRT RT_1 RT_2 RT_3 RT_4 RT_5], NULL, 8) = 0
getpid() = 29841
gettid() = 29841
getuid() = 1000
rt_tgsigqueueinfo(29841, 29841, SIGABRT, {}) = 0
--- SIGABRT {si_signo=SIGABRT, si_code=SI_QUEUE, si_pid=29841, si_uid=1000} ---
+++ killed by SIGABRT (core dumped) +++
