Hi there,
I’ve changed the Cleanup window because my server does not run at night.
Here’s what I’ve set:
Mon-Fri/11:01-11:50;Sat-Sun/11:55-12:07
I’ve done a similar config for the Client backup window and that one works fine.
Can you confirm it’s correct?
I’m running UrBackup in Docker and I’ve checked that is running in the correct timezone, however today it did not run the maintenance/cleanup as scheduled, logs do not show anything. (actually it’s been a few days, but I don’t know if before was set properly)
